Pirate wrote:
wildmanbaker wrote:
I guess I know my place now.
No, you had a good point but towing 3-5K lbs at 65mph should call for no compromise on safety. Your belief is great for the tractor or something like that.
A tractor? What do you think the stresses are when pulling a bottom plow are? Have you seen a large truck shop bend a "I" beam axel, or rear-end for camber?
To the OP: I see no reason it can't be bent back into shape. It is heavy square tubing and flat steel. This is not Ti, or T-11 that is used on the blades of dozers and loaders, or armor plate. If you are worried about it, spent another $20 and have it mag particle tested.
