ChewnMilla's avatar
ChewnMilla
Basement ac
Circuit 1 works fine when on by itself. I have tested all capacitors starters and both compressors and they all test good. When circuit 2 breaker is on it starts up and all fan comes on them the fan runs a min and shuts off. Then the amps start to rise on the panel. Shutting off 1 and just try to run 2 nothing happens. Before I tested everything I started gen and tried to run with both circuits on and it shook the rv lime crazy as the amps increased.with 2 off nothing works with gen on. Cools great with 1 on and 2 off with shore power. Any ideas? Thanks in advance.
