BigDaddy1951 wrote:
Never heard of cheated 50 amps. That might be it. Up to date KOAs and nice Corps of Engineers parks work well. Problem occurs at older parks. Can I check amps with my little volt meter?
NOT amps---line voltage. Connect your voltmeter between the 2 HOT legs. TRUE 50 amp will show 220/240 volts. IF NOT, then you have cheated 50 amp service. Doug
PS. I call it cheated, because most parks charge extra for 50 amp hook ups. IF NOT true 50 amp, then the customer is cheated. Charging for 50 amp but not supplying 50 amp.
