gonefishin77's avatar
gonefishin77
basement heater
Looking at this unit HEATER
Contacted Monaco about getting all the factory components and not sure I need to spend that much money right now. I have the wiring from the inside control panel down to the water bay and think it would be a good replacement for the factory one from Monaco.
What are your thoughts
  • That is a 12v heater. Is your failed heater 12v or is it a 120v AC heater? If you need a 120v heater Walmart has several that are quite inexpensive or as someone suggested use a low watt light bulb. I use a 25w light bulb in my water compartment when winter stored.
    Jim
  • You might want to check on the wire gauge going to the compartment. A quick check indicates that if the wire is about 15 feet long (just a guess on length) it will need to be 6 gauge to have an acceptable voltage drop (3 percent).
  • Ivylog's avatar
    Ivylog
    Explorer III
    Unless you are hooked to shore power or going down the road, that 12V heater is going to kill your batteries really fast. Many use a 100 watt light bulb even putting it on a Tstat.
