Mr_Mark1
Jul 13, 2014Explorer
5thwheeleroldman wrote:
Thanks, I'm the OP. Guess maybe a motorhome is not for me as the main reason I was interested was being able to get to the bathroom while moving. Should have realized that was not a good idea. If I have to pull off for bathroom stops, then I'm just about as well off with the 5th wheel as with a motorhome. Plus I have 17 years experience with the 5th wheel; probably not a good idea to change into something I know nothing about --- at my age. Thanks for the help anyway.
By the way, I don't MIND pulling over for bathroom stops, but you all know how hard it is to find a place to safely do so!
I think the plus is that you don't have to exit the vehicle in bad weather or if you end up in an iffy neighborhood, you can stay in the vehicle. If you can drive a truck and 5th wheel you will do just fine with a class A.
But, I understand your apprehension to change. I still have a flip-phone.
Safe travels,
MM.
