michbill's avatar
michbill
basment a/c in '07Itasca
I have an '07 Itasca 38T on a 24W workhorse chassis. The a/c , I think, is Coleman and the thermostat is Trueair. When the unit runs for a while, and even though it has not dropped to the set temp, it will shut off. If I turn the unit off at the thermostat, let it set for 10-20 min. and then turn on, with the switch for the fan in the on position and not auto it most likely come on. If I keep it in the auto, it might not. Any thoughts on: 1. why it shuts off, 2. why it will come on in fan and not auto. Thanks Bill
  • Are you positive the compressors's are coming ON? Do you hear the OUTSIDE condensor fan running? Doug
