IAMICHABOD
Oct 23, 2018Explorer II
bobndot wrote:
Ken, put a volt meter on the chassis battery and the coach batteries while at rest , should read about 12.6 volts.
Then plug in the MH to shore power and do the same voltage test , should then read about 13.4v or higher.
On some MH's, the MH converter will charge all the batteries, it will depend on how its wired. An isolator solenoid (which acts as a one-way electric gate) should protect your chassis battery from draining while boondocking etc. but that gate would open up to allow your converter to charge all the batteries.
If not, then you need to take measures to monitor the batteries not being charged.
Your 2011 Tioga should have a converter like a PD 4000 or PD 9000 series that has a charge wizard built into it. That CW monitors your batteries and kicks in the charge rate as needed while your MH is left plugged in to shore power for the winter.
Do as bobndot says,You may have a BIRD or a derivative of it my Tioga has one and I know of many Tiogas that have them,It will charge thru the Continuous Duty Solenoid Relay as mine does. It may be located in your battery bay as mine is.
It senses voltage on the coach and chassis batteries and charges the one that needs it most,when it is at full charge it will return to the normal function.
38,721 PostsLatest Activity: Apr 19, 2023
