IB853347201
Nov 02, 2018Nomad II
I have a 2010 Suncruiser and have found that to maximize battery life, turning off both is best. Keep in mind that you must make sure all 12 volt systems are off or you will drain the batteries. Dont forget your TV antenna booster or AV control box. Switch your radio over to the chassis battery.
I generally check the voltage of each battery once every few weeks and turn on the disconnect switch to recharge as needed. I have found that my batteries are generally fine for quite some time.
