Sam_Spade
Nov 02, 2018Explorer
donn0128 wrote:
Go buy a battery tender for the chassis battery. Leave the switch on. Plug in. Check battery water level monthly and your good to go.
With some models, ALL batteries are being charged and/or floated when on shore power. A quick voltmeter check on each set while shore power is active should tell you what that situation is.
And if you have a good converter/charger that really does drop to float after the batteries have a full change, then you just plug in and don't worry about it.
If you happen to have AGM batteries, there is no "water" to check either.
