Snowman9000
Apr 01, 2014Explorer
No, it should be in Use position if you want charging. If your numbers are right, there are one or more problems. Did you read the document I linked to in your other thread, the manual for the Intellitec battery control? Anyway...
Take a voltage reading at the converter in addition to at the battery. Let us know what you find. Also, take a battery reading with no power to the RV.
Look for bad negative grounds to the frame, particularly the cables coming off the converter and the battery.
