indyzmike
Jun 06, 2014Explorer
The first thing I would do is make sure that the converter is working or not. Make sure that 115vac is going into the converter and it is on, warm, buzzing, whatever. Then check the output right at the converter output terminals. You should see about 13.8 with an older single stage converter. If not, your converter is toast. If you have good voltage at the output terminals, the converter is working and you have a wiring/ground connection problem between the converter and the batteries.
38,782 PostsLatest Activity: Sep 10, 2026
