Licreek wrote:
Everything on the a.c. Side seems ok ac units are working extra. I don't have a house battery disconnect but I could manually unhook the cable to the house batteries. What should I see on the house voltage meter? Also if I turn on the generator I get 12.3 but if I start the engine I get a 13.3 reading?
that tells me your converter is not working and the alternator is
or the switch over solenoid is stuck in the motor side of charging
1)what is the voltage at the battery's when plugged into shore power??
2)when you run the engine and use the same amount of 12V power does the low voltage lit on the fridge come on?
