gutfelt wrote:
CA Traveler wrote:
I would not consider any battery change until you understand and fix the current problem. If it's bad batteries or change is being considered for other reasons then there are many considerations concerning battery type/size change. And bigger capacity is not necessarily the best answer.
OK but what if the current problem is bad batterys ?
Considering the OP has no prior knowledge he could purchase a 12V battery or maybe 2 6's and begin to learn his requirements. If he's a pedestal to pedestal person one 12V should be adequate.
Many considerations: usage, loads, charger capacity, more efficient equipment, better management, cost and the list goes on. There are many posts on understanding and improvements.
