DesertHiker
Jul 23, 2020Explorer
bobndot wrote:
I just learned something , I just asked someone re your problem.
Ask your mechanic to put a clamp volt meter onto the battery feed wire to the alternator .
A bad diode rectifier inside the alternator could be allowing battery voltage to drain back into the alternator when the vehicle is off .
The diode should be acting like a one-way valve to allow voltage to charge the battery but if its gone bad, then it allows a two way flow. That could be your problem and its something to eliminate if it is.
I have no idea what this means, but I have printed it out and will talk to the fix-it guy. Thanks!
38,782 PostsLatest Activity: Aug 23, 2026
