kioticoachman
Sep 18, 2021Explorer
enblethen wrote:
Another way to test is to put a volt meter, set to 20 volt DC scale, between the two small terminals, have helper hold switch in one position. Meter should read voltage either positive 12 volts DC or negative, then have helper hold in other position. Meter should read 12 volts DC with opposite polarity.
After the switch is removed there will be the two small terminals you mentioned. That will tell me I should be getting 12 volts DC both ways? Positive and Negative. Good idea ... I'll see what I can do by myself. Thanks for sharing.
38,782 PostsLatest Activity: Sep 02, 2026
