Oldcoots's avatar
Oldcoots
Battery Disconnect
I have 2005 Fleetwood Providence, the main & coach battery rocker switches are on the main panel in the coach. The problem I'm having is I cannot switch them off? The switches act like a breaker that had tripped. Is there something that needs to be done to reset or a fuse some where I can check?
  • Posted: 01/12/15 03:07pm Link | Quote | Print | Notify Moderator
    They usually toggle in two directions (connect/disconnect)and return to center. If you lose power in the rig try toggling it in the other direction. If you still can't get it to work then check the solenoid - probably an intelitec design and they have a couple of fuses on the solenoid that you should check.
    Kevin
    Kevin can you direct me to where the solenoid is and would this be where the fuses would be?
    I look forward to hearing from you
    Thanks
  • They usually toggle in two directions (connect/disconnect)and return to center. If you lose power in the rig try toggling it in the other direction. If you still can't get it to work then check the solenoid - probably an intelitec design and they have a couple of fuses on the solenoid that you should check.
  • Ray_IN's avatar
    Ray_IN
    Explorer III
    Most of these switches trigger a solenoid that actually disconnect/connect the house batteries, and return to a neutral position when released. You may confirm this by turning on a light in the coach,(when NOT on shore power) push the disconnect side of the switch and watch the lights.
  • Sounds like you have lost control power.
    Do you have a master switch by the entrance door. It could be in the off position.
