JCat's avatar
JCat
Explorer III
Sep 27, 2019
Battery Hold downs
The batteries in my RV are held down with metal L shaped brackets that go around the edge of 2 batteries and then are bolted to the floor. Over time these have begun to corrode due to the battery fumes/liquid.
So I need to replace them.
I want to go with a better solution, that won't corrode out.
I was thinking plastic brackets or a metal bar attached to the bolts.
What have you guys done and how did it work ?
  • Go with a battery that doesn't cause corrosion. AGM
