ksg5000
May 29, 2013Explorer II
When you say your battery reads "Good" what meter are you using. The battery meter that came with your rig is practically worthless and if your using that as a basis for your concern then stop.
Further - unless your converter has been changed/upgraded you likely have an old Magnatek which are lousy - slow to charge batteries. Also - what type of battery did you install - your rig probably came with a type 24 battery which is pretty small and good for about 3 or 4 days of dry camping.
Not sure - but it's possible that things are working as designed.
38,782 PostsLatest Activity: Sep 10, 2026
