jimwooster wrote:
Having an issue with my class C battery. When I am driving or motor is running all the 12 volt systems work. When I shut off the motor none of the 12 volts work. Had the battery checked and it is fully charged. Any ideas? Jim
Are you and BrianButler the same? You seem to be having the same exact problem at the same exact time (6:40 p.m.)... Not being snarky, just thought that strange that two different people would be posting the same exact problem at the same exact time in the same forum.
Is this a sudden problem with a motorhome you've had for a while? Or a problem with a new (to you) motorhome?
