CA_Traveler
May 06, 2013Explorer III
rv4jimnme wrote:Since the cord got worn it could have shorted blowing a fuse.
This sounds like you once had a charge line but it no longer works. Check the rig fuses etc.
Sorry CA Traveler do you mean fuses on the motorhome and or CRV? THANKS SO MUCH TO YOU ALL
Actually a charge line should be fused at both ends. You may also have a disconnect relay in the rig so that power to the toad is only supplied when the rig engine is running.
