Bordercollie wrote:
I use a ResMed Airsense 10 CPAP with humidifier and heated hose features disabled. I use a ResMed 12vdc to 24vdc converter,($100) connected to two (2) 12volt 18 amp hour sealed lead acid batteries,($100 per pair) connected in parallel, for 12 volts 36amp hour capacity.
Hi Bordercollie
I'm wondering why you put the two 12V batteries in parallel when your CPAP needs 24V? If you put them in series, you'd be at 24V with an 18 AH capacity. Power wise, it's the same. That 12V to 24V converter uses up a bit of power in the step up conversion process. Maybe not much, I didn't research the technical data for the unit, but it does use some power.
Since that converter costs what a pair of batteries cost, for the same initial investment, you could have an extra set of batteries. This way one pair of batteries could be charging and standing by while the other pair was being used. This would provide you at least 6 days, maybe 7, of battery use. Of course, since you already have the 12V-24V converter, it's a moot point. But if it should start acting up, this might be something to consider, if you haven't already.
Anyway, I know nothing about CPAPs and such, and I guess the 12V to 24V converter is something you'd use for other purposes anyway. I was just wondering if this was something you investigated along the way.
Take care,
~Rick
