- rgatijnet1Explorer IIIAs I sit in my coach, watching a crystal clear picture on my TV with my Jack antenna up in the air, I care little about anyone's tests, no matter how knowledgeable the tester is. If I am receiving a crystal clear picture because of a repeater, so what? WE typically put 15,000 miles a year on our coach in the West and the East, stay in small towns and large, and I cannot remember the last time I was unable to pick up the network channels with my Jack antenna at any location. My own personal experience in my coach trumps any test by anyone. :B
- Dutch_12078Explorer III
rgatijnet1 wrote:
Dutch_12078 wrote:
rgatijnet1 wrote:
Bill.Satellite wrote:
If your existing Winegard antenna is working, the Jack is going to be a downgrade. Many stories of people replacing non-working or very old Winegard antennas with Jack's a getting great results. Well, of course they are!
If you stay in close to town then the Jack will perform very well, it is a good antenna. However, it will not bring in NBC in Las Vegas as they are still broadcasting NBC 3 on VHF channel 2. The Rayzar Air will also not receive these channels. The Sensar's long arms are required to receive channels 2-6 and there are still multiple markets that use channels 2-6.
If you do a search Batwing vs. Jack (or similar) you should be able to find the comparison done by JVCJeff (JCV?). It is an excellent report.
Way too many variables for you to make such a blanket statement. Our last time in Moab, Utah, we were able to use our Jack antenna and pick up 26 channels with some being as far away as Salt Lake City, Utah. This was with a range, in the mountains, of over 120 miles. Over flat land out west, our range has been greater.
There have been very very few instances where we could not pick up all three of the network channels, no matter where we are parked.
How many low-VHF channels (broadcast, not virtual) have you picked up at that distance? There are still 300 plus stations broadcasting on the low-VHF (2-6) channels in the US.
Who cares? That number of 2-6 channels is getting smaller every day as the stations upgrade. I'm more interested in the future than the past.
If missing out on available network channels, low power repeaters, etc., doesn't affect you, that's fine with me. Others may find the information about the low-VHF channel reception useful though, when making an antenna selection. The bottom line is that tests run by knowledgeable people with the proper test equipment have found the Sensar batwing with the Wingman add-on to be a more efficient antenna under more circumstances than any other OTA RV specific antenna. Here's a link to one thread on this forum showing the comparison testing done by one of our own very knowledgeable forum members:
Batwing vs.BatMan vs. Jack: The Results.. - jorbill2orExplorer IIThe Razar and the jack are good antennas and are less directional. .. Put it up it works and most people find that as the definition of better . the batwing with wingman attachment is more capable of distance but must be pointed accurately and then moved if the other stations are in a different direction
120 miles for UHF is impressive and unlikely. I would think the salt lake station has a repeater in Moab ( it does) ;-) many small communities use repeaters and that's what your really receiving your siting right on top of the station
The jvcjeff post / study shows the differences very clearly . - rgatijnet1Explorer III
Who cares? That number of 2-6 channels is getting smaller every day as the stations upgrade. I'm more interested in the future than the past. - IAMICHABODExplorer III
With over 1700 stations out there it seems to be a lot to choose from. - Dutch_12078Explorer III
How many low-VHF channels (broadcast, not virtual) have you picked up at that distance? There are still 300 plus stations broadcasting on the low-VHF (2-6) channels in the US. - rgatijnet1Explorer III
There have been very very few instances where we could not pick up all three of the network channels, no matter where we are parked. - RoyBExplorer IIMy house setup here is some 50 miles away from Washington DC and has two clusters of TV stations there one on each side of DC.
Have experimented using both the BATWING with the UHF add-on dipoles and the JACK picking up the National Broadcast digital TV signals..
The BATWING seems to be the best for me doing this mounted on the same antenna pole at the same height... Both got good clear HDTV signals I had to move the JACK ANTENNA alot more to get precisely pointed at the two clusters of TV stations.
Probably the longer dipoles of the BATWING antenna setup gives it an edge perhaps...
Just my thoughts here... I have used both antennas on our off-road trips with my POPUP camper that has an outside antenna pole mounted to the side of the trailer. Both had excellent results for us...
Roy Ken - Bill_SatelliteExplorer IIIf your existing Winegard antenna is working, the Jack is going to be a downgrade. Many stories of people replacing non-working or very old Winegard antennas with Jack's a getting great results. Well, of course they are!
If you do a search Batwing vs. Jack (or similar) you should be able to find the comparison done by JVCJeff (JCV?). It is an excellent report. - IAMICHABODExplorer IIIIf you are talking about the JACK antenna, I changed out mine to it and got very good results.
I put one on my RV for 2 reasons, the bat wing was only marginal and the addition of the Wing Man was not an option because of it's size, it would not clear my A/C on the roof. Where the Jack would.
I have had great luck with it and compared it with others in our camping group that had the BatMan, when out together and got as good or better reception as they did.
I found a new one that is not much bigger and fits in the same space.
It is The Rayzar
][IMG]http://i.imgur.com/TgLwTbbl.jpg" height=220>
In a non scientific test I was able to get 20 more channels from it when doing a scan on my TV. One nice thing about it is, its Bi-Directional and gets larger field of coverage than the Jack.
On a recent outing I found that it outperformed the Jack at the same place that I had camped at before.
After I bought it and used it a while, I found a discussion Here on the NET about it.
38,766 PostsLatest Activity: Jan 10, 2026
