Chum_lee
Feb 16, 2021Explorer
Yes, in spite of the "knowledge" you glean from the internet, the engineers at Ford actually do an exhaustive amount of engine research. Even so, they still make mistakes, . . . . just like everyone else. (What a surprise!) When they tell you to change the oil at 5000 miles, they don't just pull that info from their hind quarters. IMO, THEY MEAN IT!
My 1999 F53 V10 is a 2 valve SOHC 275 Hp engine. At a later date (I'm not sure the exact year, you can look it up) it was upped to the 3 valve (315 Hp) and later to the 365 Hp engine. IMO, a phenomenal achievement for a truck engine without changing the displacement.
As someone who worked in a Ford parts department, I can tell you that if you go to the Ford factory parts website, you can look up the part number for the oil pump on the V10, 2 valve vs. the 3 valve. If it's the same, the pump is the same. If it's different, the pumps are different in some way. (maybe oil pressure, maybe flow, I don't know) You can look at the Ford Factory Service Manuals for that. They (Ford) may also use a different oil pressure relief valve, which you can also look up. Not that hard.
Chum lee
Chum lee
