Rick_Jay
Oct 15, 2018Explorer II
Diplomat_St_Poodles,
Sorry it took so long to respond. Between work and actually getting out to enjoy the RV the last couple of weekends, I haven't been on the forums much.
OK, so, I have the same slide out controller you do. I examined it physically and observed it's operation. It DOES NOT have a circuit built into it to cut power to the slide out motors when they reach the end of their travel. (There is a PIC chip (microprocessor) that's wearing a bogus part number so it can't be ID'd, but I really don't think that is working as a current limiter, just simple logic for the switches.) The relays on the board stay engaged until I release the IN/OUT button. That said, neither of my slides has ever broken a shear pin.
The slides will activate until the end of their travel, then slow down and ultimately stop. That's when I let go of the button. If I hold the button past that, the motor's apparently stall as I don't hear anything. When I release the IN/OUT button, I can hear the slide controller relays click to disconnect the power.
I did see in a pdf document I have on GBM slide operation where they specifically state to release the IN/OUT button once the slide reaches the end of it's travel to prevent damage to the wood molding. If you want me to send you the pdf, PM me with a real email address and I'll be happy to send it to you.
I'm guessing & hoping that installing the proper shear pins on your slide out should solve the problem.
If you continue to have this problem and everything appears to be in proper alignment, the only other thing I can think of is that the motor was changed for one with more torque than the original. The motor has a gear box built into it, and perhaps someone changed out an original one for one with a different gear ratio. When I bought my replacement motor, I believe I saw different gear ratios available.
My main front slideout and rear (queen bed) slideout use the same motor and my rear slide goes out noticeably quicker than my front slide due to the lighter weight. If you don't notice that difference in speed, perhaps that motor has a lower gear ratio and therefore is applying more torque once it reaches the end of the travel.
That's just a wild guess. I'm hoping for your sake it's just the shear pins.
Good Luck,
~Rick
Good Luck,
~Rick
