Diplomat_St_Poo
Oct 16, 2018Explorer
msmith1199 wrote:
I'm not an electrician so I don't know the part names, but odds are you have a bad electronic part that stops the slides. (maybe somebody knows the name) The part acts as a limiting switch, but it isn't a limiting switch. Is a self contained piece that senses a power surge when the slide is fully open or fully closed. Basically when the motor starts to draw more power when the slide hits the stops the device senses that power draw and cuts off the power stopping the slide. Your power steps have the same device that stops the steps when they are fully up or fully out. This device would also stop the slide if you opened the slide into a tree or wall.
I would have thought there was a limit switch of some sort but it would appear that there isn’t one. We thought the controller would sense a higher power draw and stop the slide. According to the builder of the controller it does not do this.
Tempest.
