Dale_Traveling
Feb 05, 2017Explorer II
You'll be close but as long as you're not loading the coach to it's limits. Per Thor's on line specs the Ford based chassis GVWR is 10,360 and GCWR is 13,500 so if the coach is loaded to maximum you'll be overweight by 100 lbs or so. If you go with the Sprinter based chassis you'll have an extra 1000 lbs to play with. Double check the hitch and ensure it is 5000 lbs capacity.
The elephant in the corner is what is the empty weight and how much stuff can you pack in.
38,782 PostsLatest Activity: Sep 02, 2026
