Chowan wrote:
Gjac wrote:
The wheel base is a little short to it overall length. I would try to find out how it handles and would also look at the CCC. Do you know what the CCC is? Also how is the actual weight distributed from the front axle to the rear?
I see what you are talking about with the wheelbase. It is one of the shorter out there. THanks.
I have not found where or how to figure the CCC. how to figure how the weight is distributed. If you can tell me how to know these things I can compare. Thanks again.
. It is usually posted in the MH. Mine were written down in my manual. The salesman should be able to research this and get back to you. Most of them won't know and rather talk about outside TV. Some dealerships have scales which is the best way. Actual weight minus the GVWR will give you the CCC and front and rear axle weights so you can compare actual weights to the weight ratings in the specs. If the front is too light compared to the rear that could effect the handling. Most replies from people with DP's will be on longer ones.
