smlranger
Jan 01, 2015Explorer
Of the four you have listed, I would certainly only consider the Entegra and the Newmar. I would compare the features of the Aspire and the Ventana (both are the respective manufacturer's entry level DP) and see if there is a difference in the features or floor plan that would tell you which is preferable. Personally I believe Newmar has a bit better build quality overall. However, if the Ventana has a rear radiator chassis, I would select the Aspire which is on a Spartan chassis with side radiator.
