Daveinet
Jan 02, 2015Explorer
My experience with Foretravel is primarily with the brand overall, not as much with the latest units. Once they hit the 1990s, the build quality is substantial. Just they way things are done are a significant step above what I would call "production" coaches. You are just jumping to a different category.
As far as renting, I look to these guys for a quality rental unit. While the format may not be a pusher, they still are well built units that should give you a sense of the whole concept of RVing. Who knows, maybe you might just end up with one, although they won't be quite as nice as the FT, they still are pretty good. It will also tell you if you can tolerate the length.
http://www.westsidemotorcoach.com/Renegade-Rentals.htm
I've been to the RV shows every years for the last 12 years. I will tell you that a Renagade is the only thing I would consider other than an FT, if I were in the market to spend big bucks.
