Daveinet
Jan 04, 2015Explorer
Miramichi cruiser wrote:Ultimately you are the only one that can answer that question, however the mileage on the FT is very low, so it is unlikely you will see any signs of wear. Take a good look at the photos of each coach with the slides out. Notice how the FT is different than the other 2. The other units use the same sealing method used in nearly every other coach out there, including your $20K trailers. Notice the FT is different. I'm pretty sure it uses an air lock to seal around the slide. (someone who has first hand knowledge please confirm) That is just one example of why one looks at an FT. I have no doubt if you saw each coach first hand, you would find many other little details that would help to clarify what you are getting when you are looking at an FT.
Do you think the FT should be in the running?
Think I should include that 97 Newmar? It has 67000miles.
Thanks for the help!
Stephen
