smlranger
Jan 04, 2015Explorer
All of the coaches in your most recent post are nice and from reliable manufacturers, for sure. The two Aspires and the Ventana are newer and that may be important to you. However, IMO, the overall build quality of the Foretravel puts it in a class above the others. Also, if the type of heating system is important to you, the Foretravel has a diesel powered Hydro Hot system which is generally considered better than the LP powered Aqua Hot systems in the Aspires. I have a neighbor with an older Foretravel and it is just built like a tank. The only negative I could see with the Foretravel is it appears that basement storage would be limited...40' coach with tag axle vs. the 42'/43' coaches. Maybe not an issue for you but something to consider.
As others have noted, you need to determine which floor plan will best meet your needs. If any of those four will work for you, I would test drive all of them then decide.
