pnichols
May 12, 2020Explorer II
billy1davis wrote:
We are looking for the most reliable Class C out there. I have run a search and have digested those results. I am looking especially for those that have had class c's.
The "overall most reliable" Class C would probably be this:
1. A Class C built on the Ford E350 or E450 chassis.
... and ...
2. A Class C built with a coach exterior structure that is made of a one-piece fiberglass shell. i.e. The entire roof and walls are molded as one continuous fiberglass unit.
As far as I can tell, the Coach House Platinum models may be just about the only Class C motorhomes still available new that are built this way - including the Ford chassis.
The next closest Class C models built almost to the above criteria are probably those built by Phoenix Cruiser - including the Ford chassis.
P.S. By "reliable" I assume you mean A) least likely for the chassis to break down over time - but easiest and cheapest to get repaired if it does, and B) least likely for the main coach structure to develop water leaks and generally hold together over time.
