bobndot
Sep 19, 2018Explorer III
I started doing things this way in order to have a portable system to switch from rv to rv over time. There may be better products on the market but what I use works and has been working without incident.
First I check the pedestal using a Surge Guard 34930
to test the pedestal. If all checks out and the voltage is good, this is all I use. Been using this one for 4 or 5 yrs. , this is my normal most used set up. ( my model is actually the older version , I think its a 34830 model . Same basic product AFAIK.
https://www.technorv.com/surge-guard-portable-total-electrical-protection-34930/
On occasion , if the voltage is too low and needs boosting, I then fist plug the Surge Guard SSP 30x into the pedestal in order to protect the Hughes Autoformer which boosts voltage to a normal level. After the Hughes I plug in the 34930 .
This is what I plug into the pedestal first. http://www.progressiveindustries.net/ssp-30x
Then I plug in the Hughes .
The SSP 30x protects the Hughes which boosts voltage which is then protected as that voltage enters the rv . The whole setup gets padlocked to the pedestal and it's kept inside a large Tote box.
http://www.adventurerv.net/hughes-autoformers-voltage-booster-amp-p-2779.html?gclid=CjwKCAjw54fdBRBbEiwAW28S9qW_7fPerv9FswnNAyN3Ee28xJpZRkv7tYJ6U9sT54C52y-ZsS9hbhoC7j4QAvD_BwE&utm_campaign=partsfeed_ppc&utm_medium=cpc&utm_source=Froogle
38,768 PostsLatest Activity: Nov 21, 2015
