wolfe10
Apr 27, 2016Explorer
Really two different questions here. Speaking from DP perspective, gas will be slightly different.
Best economic speed, flat ground: At peak torque RPM in 5th (not 6th gear). This is from my ScanGauge D. This is generally too low a speed for safe highway driving.
Best economic speed, rolling hills: About 200 RPM above peak torque RPM in 5th gear (so that it does not downshift on every hill).
Best REASONABLE economic speed, flat ground: At peak torque RPM in 6th gear.
Best Reasonable economic speed, rolling hills: About 200 RPM above peak torque RPM in 6th gear.
Note: some manufacturers chose gear ratios that really don't give you a "good MPG" speed/gear-- to be in 6th gear, your speed is such that aerodynamic drag is significant.
38,769 PostsLatest Activity: Jul 09, 2020
