Sam_Spade
Nov 30, 2015Explorer
Bobbo wrote:
Don't forget that this particular trickle charger monitor's the chassis battery's state of charge, and if fully charged, turns itself off.
It appears that you are not getting it.
I will try one more time.
The NAME not withstanding, a unit that works like that should NOT be referred to as a "trickle" charger because trickle chargers apply a small charging current flow the entire time that they are connected and turned on. One that automatically vaires the current or automatically turns itself on and off should NOT be called a trickle charger......because it is NOT.
38,783 PostsLatest Activity: Sep 23, 2026
