time2roll
Dec 02, 2017Nomad
I will advocate for separate components. Not sure but I think the PD-9055 is a fixed voltage converter and should be upgraded with something like a PD-9260. PD-9055 does provide clean DC power at 13.6 volts. The old Magnetek would be the one to avoid.
As for inverters I have and recommend GoPower brand. Seems better than Xantrex anyway. Just get a stand alone inverter for the power level you need. Separate transfer switch or switches as needed for your install.
When something goes wrong it is far easier to know what it is and only replace what has failed.
If 'best' means lowest price you are on your own.
38,782 PostsLatest Activity: Sep 01, 2026
