pianotuna
Dec 02, 2017Nomad III
Hi,
I have a hybrid Magnum inverter/charger. If I were to replace it I'd go to Victron. I use the load support feature almost all the time. When I had stand alone inverter and converter I enabled double conversion any time there was only a 15 amp shore power supply.
The other company I would consider is Outback.
My typical plug in configuration is shore power-->autoformer-->inverter/charger (with load support)-->RV power system.
I "dial down" to 80% of what ever shore power I have, so a 15 I draw 12, 30 I draw 24 and 50 I draw 40 from one leg and 30 from the other.
On generator power I "dial down" to 23 amps.
Best price on the Magnum is from Imarine.
38,782 PostsLatest Activity: Sep 01, 2026
