time2roll
Dec 03, 2017Nomad
cm2785 wrote:I assume 50 amp RV. Magnum seems to have a two pole 30 amp switch so you cannot really wire the whole RV without a separate 50 amp two pole switch.
Thanks guys I’m looking at the Magnum and while it’s going to be a $2500 investment it seems to be a great unit for my electronics but would that unit require the whole rig to be rewired? I’m in Los Angeles and need to find someone who is good at installing these.
You can use 2x 30 amp switch in parallel (for 60a rating) to power one side of the 50 amp panel. Then swap inverter loads to that side and non inverter loads to the other side. If the balance does not seem to work well you can also do a subpanel. Otherwise you can wire the inverter the way it will work best for you however you need a plan so it can be set up correctly.
38,782 PostsLatest Activity: Aug 31, 2026
