time2roll
Dec 03, 2017Nomad
cm2785 wrote:Still need to know what circuits you want powered.
I’m on a 30amp system in my rig
I suspect:
1) GFI outlets
2) Other outlets
3) Microwave
Two branches is easy as it has a two pole transfer switch. Three may require a third switch or a sub-panel.
Your existing converter would be disabled. And the absorption fridge may need to be moved off the GFI branch circuit or wired before the inverter.
I assume no air conditioning or electric water heat. But you could easily just power the whole panel and remember to turn things off or switch to propane as needed.
BTW I recommend 6+ batteries to drive this thing. Might get by with 4 with light use or AGM.
38,782 PostsLatest Activity: Aug 31, 2026
