2oldman
Dec 03, 2017Explorer II
cm2785 wrote:That's fine, but an 'expert' will probably try to make it as expensive as possible, meaning installing perhaps a sub-panel and only selected outlets being inverted. That will convince you you're being "safe", and according to some on here, you are. The problem comes if you ever have to sell the coach and try to remove the IC and put all the wiring back the way it was. Kind of a problem.
This is why I need to hire an expert to wire it.. I don’t want any problems when connecting to shore or gen.
If you tell your installer to do what I said, it'll be connected to everything, just like shore. Removal is also a snap.
It's your choice.
38,782 PostsLatest Activity: Aug 31, 2026
