pianotuna
Dec 03, 2017Nomad III
Hi,
Then wire a 30 amp outlet and power that from the inverter. Plug in the shore power cord.
Manually set the fridge to propane. Unplug the converter. Done!
Since you are considering the Magnum, be aware it does not "like" some shore power gfi outlets. The best price may be at Imarine.
As I said earlier, I have the 3012 Magnum. If it fails I will move to Victron.
cm2785 wrote:
I’m on a 30amp system in my rig
38,782 PostsLatest Activity: Aug 31, 2026
