msturtz
Dec 03, 2017Explorer
2oldman wrote:cm2785 wrote:No. It's very easy to simply hard-wire it to your coach's AC panel just as your shore cord is. Done, and done. Entire coach is now on inverter.
but would that unit require the whole rig to be rewired?.
No need to re-wire the coach. The Magnum inverter can be wired to the existing inverter DC wiring. The AC can also use the existing AC wiring. The Magnum inverters have an internal transfer switch. The only choice you need to make is if you want to add circuits to the inverter.
38,782 PostsLatest Activity: Aug 31, 2026
