ronfisherman
May 27, 2016Moderator
Most Class C have the smaller size frig.
Here is one I researched.
Whrilpool 10.7 cu. ft. Top Freezer Refrigerator
Your current problem may be a simple as gas orifice needing to be cleaned. When unit is running on gas you should hear the burner. Not as loud as a water heater.
If not remove orifice and soak in alcohol. Then blow out with air. Reinstall and should have better operation of frig.
Mobile tech told me that spiders like LP and lay eggs in the orifice. Blocking it from full flow.
