IAMICHABOD
Feb 14, 2016Explorer II
Most will say the Winegard,but I have had a lot of luck with the Rayzar air. I had a clearance problem,just be sure to check yours.
I installed a Rayzar Air several months ago.
When I bought my RV it had a Batwing that was not working, I cleaned up all connections and tested to see if it was broken, it was,so I replaced it with a new bat wing then ran a Channel Scan I was not impressed with the amount of channels that I got. This was done in my driveway here in the south bay of So Calif using my SensarPro.
I then went out and got a Wingman add on like the one pictured above, that put my channel scan up to 47,but I had a clearance problem with the Wingman
So I opted to put a Jack on and my channel scan went up to 60
I then went with the Rayzar as you can see it fits in the same space.
I opted not to put it on the supplied 13 In. arm. I kept one arm of the Winegard mast and mounted it that way,there are instructions in the kit,it is very easy to do. This way I had it in the same space and got the maximum height when deployed.
][IMG]http://i.imgur.com/TgLwTbbl.jpg" height=220>
The Bi-Directional feature is great and easier to use than the Jack and I get several more stations.
38,763 PostsLatest Activity: Dec 05, 2025
