rgatijnet1
Sep 25, 2013Explorer III
harold1946 wrote:rgatijnet1 wrote:harold1946 wrote:rgatijnet1 wrote:pianotuna wrote:
Hi,
Glass is not magic--but when light hits a surface it changes frequency and becomes heat. Since there are no "perfect" reflectors, quite a bit of light energy becomes heat. Glass is NOT a good transmitter of heat. Remember, too, that light waves of all frequencies will bounce off the surface of the glass. That adds to heat inside the RV if the reflective layer is inside. So it is better to cover the outside of the glass--preferably with an air gap if that can be arranged.
There is a reason why Florida is called the Sunshine State. We get plenty of it and we learned the best way to deal with it a long time ago. If you think you have a better way, go for it. I'll stick with what works the best, after trying the other methods. :B
I guess all of the millions of homes, in the sun belt, with sun shades on the outside of the windows must have wasted their money. Its simple high school science.
Then I also guess that all of the thermal pane windows, used in the sunbelt, that allow sunlight to penetrate the first layer of glass before hitting the reflective surfaces that reflects the heat back out are not engineered properly. They have a few engineers that worked on their design and the R values certainly support the fact that sunlight and heat can go through the first glass surface and be reflected right back out. This may be advanced college science.
This is becomming interesting. Please give me one link with test data that supports that claim.
I would also be interested on how reflective film reduces the heat being transfered through the aluminum window frame of an rv.
With exterior shading that transfer is also greatly redused.
Less heat transfer through the glass and less through the frame.
I might also ask where you got your thermopane windshield.:@
I doubt if you have an aluminum frame around your windshield but my interior foil insulation covers all of the glass and the rubber gasket to reflect all of the heat coming through.
When I use it on the side windows, I cover all of the glass and aluminum frame.
You can also park in the shade all of the time and never have to worry about it. If you are happy with your exterior solution, fine. I'll stick with what works for me and many others that use the interior reflecting foil method. If you have a source for a true mirror exterior reflecting window covering, post it. All that I have seen are white, or some other color, that does not reflect as much light/heat as the aluminum foil coated bubble type insulation. Here is the link with stated R values for the product. Bubble foam insulationBe sure to read the 21 reviews, especially the ones that talk about windows.
Please list the R values for your exterior coverings.
38,769 PostsLatest Activity: Apr 03, 2026
