brandonrv
Jul 31, 2014Explorer
Desert Captain wrote:
Refrigeration running on propane uses very little. You may have to manually shut off the ac to the frig as most will run on ac if it is present. Simply turn off the ac breaker for the frig and it should automatically shift to propane. Save your ac for the air conditioning but if you have to run two units on high in a 26' coach I would have them checked.... but on the other hand I don't know just how hot it will be where you are camping. Good luck.
:C
Just upgraded to a 36' coach :) 2014 Fleetwood Bounder 35k and Down here in South Texas it's about 105 heat index for the majority of the day.
Fridge has a switch built in to go from LP to AC. Thanks for the input.
38,766 PostsLatest Activity: Jan 10, 2026
