valhalla360
Jul 31, 2014Navigator
Propane for the fridge should be fine but you will be pushing that 30amp outlet to run 2 AC units.
Keep in mind a 30amp outlet is actually only rated for around 25amps. You might want to check the voltage drop to make sure you aren't killing your AC units with low voltage.
38,768 PostsLatest Activity: Jan 26, 2021
