brandonrv
Jul 31, 2014Explorer
John S. wrote:
But what is the load drawing the AC voltage down too? I do not run two acs on a 30 even when I had a LP fridge. It will eventually trip the breaker. My AC units use 14 amps each and more at startup. Unless you have a EMS to guard against low power you need to look carefully at your laid there. There is a battery charger and converter running too.
Has a voltage monitor for L1 and L2. They are hovering around 118-120ish
38,766 PostsLatest Activity: Jan 10, 2026
