John_Joey
Dec 27, 2017Explorer
femailyetti wrote:
...Its some sort of sheet aluminum roof. I am not sure of the superstructor under the aluminum.
Well you're in luck then. I'm guessing when you pull down the ceiling you'll find 2 by ? cut with a radius with 1/4 plywood on top. Also guessing you might find some of those rotted where fasteners were used from the top into them that leaked.
You may have already done this, but I would push on the sides some to see if they flex. Mostly at the corners and below windows and vents (i.e. fridge.) If you do then you got some more work ahead of you.
Anything is fixable with enough time.
