k6dcp
Mar 21, 2014Explorer
Best way to stop cabinet door rattle?
My IVan has only one fault -- a rattle that will drive you crazy after you've heard it for hundreds of miles.
I think I've localized it to the curved cabinet by the sliding door, where the "kitchen" is. That cabinet has two doors. The left door seems to be fine. The right door has a catch at the top and appears to be slightly "sprung" in that the bottom of the door does not touch the frame of the cabinet. There seems to be about a quarter inch (guessing) gap between the bottom of the door and the cabinet frame.
I tried taping the two doors together with strips of blue masking tape to see if this is the problem. Unfortunately, the desert air dried the tape and it popped off fairly quickly.
I've thought of putting industrial-strength velcro to hold the cabinet door on, or a magnetic catch, or padding the gap with foam weather stripping.
But then it occurred to me that I'm not the only one, and far from the first one, with a rattly cabinet, and that you might have solved this problem before me. If so, would you please share your solution with me?
As always, thanks for your assistance.
